5.3 questions
5.3 questions
Hey guys just wanted to ask if this black bracket on the rear driver side head is necessary. Its stoping ny LS1 intake from laying flush. Also i was wondering if I need a F body steam pipe because I have a 2005 5.3 engine it has the block plates on the rear steam ports and the 2 front ones are connected but the outlet is really close to the intake. Can i just bend it a little? I see that the throttle body also has steam port connections on it also can I bypass those or do I need to connect those with the coolant steam lines? Also does the steam line just plug into the nipple on the radiator fillerneck?
If bracket, you mean the part in your second pic held on to the end of the head with 1 bolt, no you don't need it. Pretty sure it's for lifting the engine at the factory, although that's just a guess on my part. But I know for sure you don't have to keep it. No experience bending the steam line, but woukd think it's do able. Don't have to hook it up to the throttle body, that just to warm the throttle body for drivability in cold weather.
HTH, Jim
HTH, Jim
LS1Tech Premium Sponsor
You can bend the steam line, I have had to do it for other applications to get some intakes to fit, and that bracket can be removed, its not necessary.
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Okay thanks guys I was wondering if someone can post a pic of exactly where they were out it there steam line to a lot of people on another form were telling me that you have to "tie in" the steam ports tube in an existing radiator hose. Can someone elaborate on this?
I just put a 5.3 in my 1992 truck using that bracket front and back with my hoist.The picture isn't showing the hole.There is one on the driver side head rear and one on the passenger side head on the front.
You have to vent that steam port line to either a heater hose or top radiator hose....search "jags that run" they sell a nice inline adapter for the radiator hose which has a 90 degree nipple to connect the hose to the steam port and another port with a petcock to bleed air out of the system...I believe the adapter is $33....OR you you could drill and tap the water pump and vent the steam port there
The Scammer Hammer
I knew I'd find it eventually. The question has come up before.
https://ls1tech.com/forums/generatio...e-bracket.html
