whats the biggest intake manifold, set of heads I can put on my ls1
Im just wondering what is the biggest size intake manifold and set of heads that I can put on my ls1 ive been looking around, but I would just like a little more help/info. Thanks.
Captain Double Post
Fast 102 is the biggest, listen i will say this,extreme setups cost way more/need every lil supporting mod to make it a runner,you dont need the biggest baddest cam/heads/intake etc with these cars, i have seen some pretty high dollar setups get worked by just a well thought out setup,what are you plans/goals?i assume you already have a cam since your question is just about intake n heads?a fast 102 is a great setup,but pending on goals i might just go with something smaller,imo fast intakes are like one of the last mods you should do,just because a ls6 is that good of an intake for a really good price, is a fast better than a ls6? By far,but not all the time is it worth it
LS1Tech Premium Sponsor
BOBS99SS is correct, the FAST 102mm is the biggest on the market other than running a carburated intake manifold, but just because its that biggest doesnt mean that your setup requires it. It really depends on what you do with the car, and other supporting modifications.
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
