When to change valve springs?
AFR 205 heads with doubles.
My cam is a split custom grind (sorry no specs).
Bottom end is stock dyno is 440 RWHP.
I have not been real hard on it.
When should I change out the springs?
I was told at 20k.
Any recommendations would be helpful.
Thanks.
I was told at 20k.
Thanks.
With that tiny amount of details, the easiest thing to tell you is to pull a few and check the install height. Brand of valve springs, ramp rate, lift, rocker ratio, etc all will effect the spring longevity.
This guy is a friend of mine.He has a custom grind cam app:232/236 585 ish on the lift
lsa is 111,AFR 205 heads(dual springs),Harland sharp roller rockers,hardned pushrods,kooks
long tubes,custom tune,440rwhp.I hope this info helps.
