5.3 228 cam peaking aroun 6200 rpm?
Old 10-09-2012, 12:09 PM
miguelc's Avatar
Default 5.3 228 cam peaking aroun 6200 rpm?
greetings
My car is: fox mustang
5.3 form 2008 silverado
2500 precision stall
1 3/4 headers
2 1/2 exhaust X pipe, magnaflows
truck intake
243 heads milled .050 to get 11:1 compression
A friend got a regrind he never used it only says 228 intake 230 exhaust 114
.500 lift on both, I plan to use it on a 150 wet shot
since we are at 5200 ft elevation I feel 298 hp on locked converter seems fine, but power is peaking at 6200 rpm and keeps to 6400 ( 25 hp lower). So I need a cam with .550 lift or more duration to keep HP up to 6500 rpm ? or a ls6 intake will extend my powerband?
Thanks for your help
Old 10-09-2012, 12:14 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
More duration will make the power carry higher in the powerband better, assuming you still have valvetrain control.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 10-09-2012, 04:18 PM
99Bluz28's Avatar
A ls6 intake will help with the top end, but I'd consider at least getting a low mileage used cam that's not a re-grind around the same size so you'll make better power and actually know what you have. IMO. a 228/230 114lsa should peak higher than 6200.
Old 10-10-2012, 10:05 AM
mark21742's Avatar
I'd look for something around a .550-.600 lift and an ls6 intake....Matt up above me can recomend and get you the right cam for a good price
Old 10-10-2012, 10:14 AM
kinglt-1's Avatar
Im suprised it carried that high in the rpms with a truck intake...
Old 10-10-2012, 11:00 AM
Sales@Tick's Avatar
Ding ding ding.
Lift has NO bearing on peak rpm.
Your truck intake and the size of the 243 heads intake runner and intake valve does.
You could force the motor to peak at a higher rpm with that intake, but for one...it'd take a much bigger cam than what you have now, and for two it would so inefficient it'd fall flat on it's face after it peaked.
Old 10-10-2012, 12:06 PM
wildcamaro's Avatar
That cam seems a little large for a 5.3, especially since you only have stock heads. 243 heads stock usually fall off after 550 lift...
Also are you sure about that cam being only 500 lift? That is a stock cam type lift number...also by you saying it is done making power at 6200rpm sounds like it might be a stock cam...at least those foxes are nice and light so you don't need tons of power to be fast
Old 10-10-2012, 04:43 PM
Sales@Tick's Avatar
Stock cams peak at 5500-5700rpm.
Now what they carry too is a different story, but they peak much sooner than 6200rpm.
Old 10-10-2012, 09:15 PM
99Bluz28's Avatar
Okay makes sense now, I totally over looked the truck intake, I was thinking LS1 intake.
I'd definitely upgrade to a LS6 intake, and still consider a better cam!
Old 10-10-2012, 09:31 PM
wildcamaro's Avatar
Oh I didn't even see truck intake...that's the limiting factor on the rpms, should be getting good bottom end though...even an ls1 intake would raise the useable power in the high rpm, but ls6 is the way to go...
Old 10-11-2012, 09:21 PM
Turd Gen Guy
1nasty86's Avatar
throw a tbss intake on that ****
Old 10-11-2012, 09:43 PM
miguelc's Avatar
it has a TBSS intake, engine came from a 2008 silverado. I am trading my TBSS intake for an LS6
Quick Reply: 5.3 228 cam peaking aroun 6200 rpm?
