LQ4 dropped a valve
LQ4 dropped a valve
I had a customer bring me an engine to put in his hummer h2, and it dropped a valve (broke a valvespring), and pushrod is bent. Supposedly the engine he brought me was a 35k motor that sat around for 3 years, was really hard to break free to rotate engine over. It happened while doing a CKP relearn. ****! Anyways, any idea what to tell this guy? Is the engine salvageable?
Was there simply piston to valve contact or did the valve get demolished? Have you pulled the heads to assess the damage and find out what the piston face and cylinder walls looks like? It is unlikely such an event does not warrant a tear down. You would not want to assume the oil filter would catch all of the deb-re and simply replacing the damaged parts and going on. If any metal fragments remain it is possible for them to prematurely kill the mains/rod/cam bearings.
You won't know if the motor can be saved without a rebuild untill you pull the heads. If it was hard to get to spin over you should have had the heads off to inspect everything before you did the swap.
I did tell him the engine turned over hard and he insisted that the engine is good, and said put it in. This guy is unreasonable, and doesnt understand things like the dipstick tube crumbled from rust, and the starter solenoid studs snapping off instantly from heavy corrosion on the undercarriage of this thing (truck was driven, then sat for 3 yrs, ouside in a field or something).
LS1Tech Premium Sponsor
Tough spot there. Did you note the issues before hand and have him sign an estimate or disclosure/liability statement?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Hate to say it but sounds like a customer that is going to cost you money either way be it fixing this or badmouthing you if he is unhappy. I might try a fresh valvespring and a leakdown test if you really want to avoid pulling the heads.
Just maybe..
Given what U R now saying: Mr customer, do you wish to have this repaired, pulled back out, so you can return it, or?? In any case, the expenses for doing so are this many $$$$....End of story.
In any case, if he tries to jack you around, it would be time to file a mechanic's lien on it...
you'd have gotten some different views, had you posted this "new info", to begin with.
Good, it sounds like he's willing to help. Not sure what kind of shop you are (size-wise), but I can't imagine anywhere offering a warranty on a used, customer-supplied part. If I were the customer, I would in no way expect to be compensated for what happened.
Well, removed the head, and the piston was not bad. I installed a new gasket, bolts, and took the head off his other engine. Started right up and is back on the road.
