364 vs 402?
364 vs 402?
I've got a stock bottom end LQ9 in my Fox right now. It runs pretty good to me at 10.50's @ 128. I wanted to spray it, but not with the pistons that are in it (long story).
I have another 6.0 engine. I thought about putting some forged rods and pistons in that motor over the winter, then putting my top end on it so I can spray the car.
BUT, by the time I buy forged rods, pistons and have it balanced for a few hundred more I can buy a stroker rotating assembly and make it a 402.
I want to stay on pump gas for the NA runs, so I'm not sure how much I'd benefit from the extra cubes or if it would be worth the extra $'s
What do you think?
What do you think?
A "cheap" rotating assembly will need to be rebalanced so consider that when eyeballing prices. IMO the cost difference will be mostly polishing the stock crank journals vs. purchasing a new aftermarket crank, and if a chinese crank the machineshop might even find it needs some machining touchup(more cost) before it can be used.
If you have the budget go for it, but if you are looking at things and thinking it is a $300 total price difference than forget it because the final extra cost is going to be a lot more than you think when just looking at the catalog
stroke it. You will most likely regret it later.
The following users liked this post:
NewOrleansLT1 (07-05-2023)
Im on this fence myself, and what makes it harder is i have a completely bare LQ4, so i have a blank canvass. Do i get a stock crank a forge the rods and pistons for a 364ish turbo build, or stroke it to 402/3/8 size? The added cost of a forged crank is 800 to 1000 depending on brand where a stock LQ4/LS gm crank can be had for 200 or less, and has been proven to handle 1000hp. I know forged can add piece of mind, but trying to figure where to spend money is the hard part when deciding in this area. Keeping the power streetable in a 1000hp turboed engine is hard only cause theirs so many options now lol
ddnspider (06-27-2020)
NECROMANCER! 😁
Well its either dig up the dead or beat the dead horse in another thread. Plus alot of these threads are either out of date or need people to see that people have been asking thesame questions since 2005. At least it keeps the google searches smaller
The following 2 users liked this post by JoshuaGrooms83:
98Zeric (07-19-2020), NewOrleansLT1 (07-05-2023)
NECROMANCER! 😁
The following 2 users liked this post by Che70velle:
99 Black Bird T/A (05-19-2022), G Atsma (06-29-2020)
The following 3 users liked this post by CattleAc:
Oh the hurt.....
*BRING OUT YOUR DEAD! 😁
but in any case, im at this stage in my life where I can afford, and have time to actually do something like this finally. ive had the car since 2005, and other than the typical mods, the old 98 LS1 has been unmolested other than an LS6 manifold.
I got myself a 6.0L bareback cheap that I couldnt pass up, and honestly, I almost wished the crank was still in it, cause then i would have been left with one less option really lol, but now the possibilities are only up to my wallet and how much I really wan to spend in time and money.
I want to build a street stomping LS with turbo, and either route can do it, its just how hard do I want the engine to work to get there?
Whats the trade off between going the forged stroker 402 or a stock/forged 364 route with boost building power up to say 1000hp for example? low 93 friendly CR with meth/water decent flowing stock heads and a turbo friendly cam with a healthy fuel system feeding it and a tune that won't melt the pistons or send them priority express threw your hood? Obviously the more power the engine makes N/a, the more it will make under boost, and less booat will be needed to get there.
Moderator
Received 1,836 Likes
JoshuaGrooms83 (07-07-2020)
