long crank 99-00 LQ4 with ls1 t56
Your best bet is to swap carnks. One thing nobody else has mentioned is the clutch. With that crank it's also going to be .400 closer to the tranny which is going to cause throw out bearing problems. That's going to be an obstacle you will have to overcome with the longer crank. Just swap it for a short one.
Im in this situation. Why won't it work? I thought the problem would be that the clutch diaphragm might get pressed into the release bearing. Do you know?
