Changed cam and lifters slowly lost oil pressure metal in oil (pics inside)
Old 12-27-2012, 05:04 PM
01 blue ss's Avatar
Default Changed cam and lifters slowly lost oil pressure metal in oil (pics inside)
I changed the cam in a friend's car with him and the car slowly lost pressure and went all the way to zero after about a little more than and hour of driving. The cam is a TSP 228, LS7 lifters, springs and new trays. Re-used the stock timing set and threw it all together. It ran and idled fine but still needed to be tuned. Drove a bit then lost pressure. Pulled it down and the cam sprocket rubbed the retainer plate and the cam retainer plate gasket looked torn. I wouldn't think that the retainer would let the oil pressure go to zero, maybe low but not zero. I still can't see why the retainer plate was rubbing. It was bolted to the block tight. Here are some pics and maybe you guys can tell me.
Old 12-27-2012, 05:16 PM
DaddySS's Avatar
Did you turn the cam afetr you bolted the plate on, did it turn freely?
Old 12-27-2012, 06:28 PM
Boost-box's Avatar
Pull the cam back out and check the bearings
Old 12-27-2012, 06:48 PM
wildcamaro's Avatar
I wouldn't run that cam retainer plate since some of the embossed oring is missing, that would be the cause of low/no oil pressure for sure...
Old 12-27-2012, 07:37 PM
jay7199's Avatar
yup, I bet this is the problem as well, replace it and see how it does OP.
Old 12-28-2012, 01:27 AM
joecar's Avatar
How can the retainer plate gasket be torn if it was facing the block...?
Old 12-28-2012, 06:21 AM
Gray86hatch's Avatar
What about the bolts on the retainer that were rubbing on the gear
Tim
Old 12-28-2012, 07:38 AM
Old Geezer's Avatar
What Tim and Joe said^^^^^^
This made no noise when you started it?
What do the bolt heads look like?
Looks like the damage to the area around the plate bore is not the same depth, all the way around. Plate looks to have been on crooked?? [Or, left loose]
Were the bolts torqued, prior to completion of the install?
Ne of the lifters damaged from cam walk?
Old 12-28-2012, 08:53 AM
wildcamaro's Avatar
Yea use some blue loctite on those retainer bolts for sure...
Old 12-29-2012, 09:58 AM
01 blue ss's Avatar
Well what we came up with is that my buddy was kinda not double checking himself and the bolt backed out and caused the issue. I wasn't there to watch when he put the timing set together. I slid the cam in for him and had to leave then he did the rest. Picked up a new retainer plate and gasket and new sprocket. It will be back together next week and we will see how it goes.
Old 12-29-2012, 03:28 PM
RobsZ28's Avatar
I would pull that engine out of the car and clean the metal out of the oil. I had the same thing happen to my car I changed the cam and put too much red Loctite on the cam bolts some dripped out and hardened between the gear and the retaining plate. When I started the car and run it the loctite ate up the back of the gear causing it to walk back into the retaining plate and bolt. My plate and gear looked just like the ones in the pictures. All that metal floating around in that oil isn't good in about 100 miles it tore up the #1 rod bearing and the crank. The metal shaving floating around in the engine oil is going to cause some damage.
Quick Reply: Changed cam and lifters slowly lost oil pressure metal in oil (pics inside)
