Flycutting pistons and nitrous
How much can you flycut stock pistons and still run a 150shot? I will be getting a new cam soon and im trying to decide if I should flycut so I can run a bigger cam.
What is your PTV as of now? I would measure where your PTV is now, and cut what you need. Not worry about cutting max relief. If your that bad with PTV you might need to go another route. I've heard of guys cutting .080" all day and being fine. I have no personal experience with flycutting or do I know the answer to your question. I am only trying to look at the problem in a different perspective. Good luck with you search.
Last edited by FEAR LS; 01-08-2013 at 08:50 PM. Reason: Edited: "Dumbass" moment...
What is your PTV as of now? .1 is one tenth, and .100 is a hundred thousandths, huge differences in measurement. Not trying to be a smart *** or anything. I would measure where your PTV is now, and cut what you need. Not worry about cutting max relief. If your that bad with PTV you might need to go another route. I've heard of guys cutting .080" all day and being fine. I have no personal experience with flycutting or do I know the answer to your question. I am only trying to look at the problem in a different perspective. Good luck with you search.
Im waiting to mill the heads to get compression but still run a larger cam. Im looking at the Tick Performance stage 3 saturday night special cam and I have PRC stage 1 ls6 heads, that need to be rebuild. Im trying to decide if I should mill them to 58cc,60cc,62cc. Right now they are the stock 64cc.
.080 INTAKE AND EXHAUST WOULD BE GOOD. Just deburr reliefs nicely to avoid hotspots.
Try for 11:1 ratio SCR. Good for most fuels and get a cam with a max 8.5 DCR.
