F body camaro 99 flywheel weight
Ok. I have question and a problem at the same time ,
Question, I have camaro 99 I wanna know what is the weight of the flywheel of the stock camaro .
Problem is that I got new clutch and when I put it in the top of the flywheel there is small gap between the clutch and the flywheel .
And if that is the problem then im going to have a new clutch Monster Clutch - Level 3 Package is there any suggestions?
Is the disk backwards? That would keep it from sitting flush on the flywheel. I agree the weight of the flywheel doesn't hold value to your question.
Now if you are referring to a gap between the pressure plate and the flywheel, how big is the gap? Is there a gap where the bolts are?
Not to be a dick by any means, but if you were to post this in the Manual Transmission section of the forum you'll probably get way more info and responses.
Try google'ing the flywheel weight. I've found it before using google, I can't recall what it is though. Good luck with your issue.
forget about the weight I found the answer of the question but the problem the clutch isn't straight so I'll ship the clutch back to summit and ill get a new one the monster from texas speed performance level 3
