howards cam?
Old 02-11-2013, 11:09 PM
mdabbott2009's Avatar
Default howards cam?
hi guys first time poster here.looking to start buying parts for a 6.0 build was woundering if anyone used or herd anything about howards ls cams.
cam specs are
Cam Style:Hydraulic roller tappet
Basic Operating RPM Range:1,600-6,600
Intake Duration at 050 inch Lift:218
Exhaust Duration at 050 inch Lift:224
Duration at 050 inch Lift:218 int./224 exh.
Advertised Intake Duration:268
Advertised Exhaust Duration:274
Advertised Duration:268 int./274 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.604 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.612 in.
Valve Lift with Factory Rocker Arm Ratio:0.604 int./0.612 exh.
Lobe Separation (degrees):113
Camshaft Gear Attachment:3-bolt
Computer-Controlled Compatible:No
motor will be well hopefully be a 370 with prc 2.5 5.3 heads
thanks any info be awesome
Old 02-12-2013, 08:25 AM
BKsNHRA's Avatar
For a 370. I'd go a little bigger. I'd be lookin more in the range of 227-235. That's just my opinion. I'm sure others will chime in.
Quick Reply: howards cam?
