High Compression 6.0 Build ?'s
Hey guys, im thinking of throwing a motor together for nitrous. How does this sound....
LQ9 Iron Block
Wiseco +12cc Pistons (4.030)
PRC 2.5 LS6 Heads
Custom Grind cam that im unsure of which way to go
Compression should be around 13.5:1
Forged rods/Crank
Single Plane intake
Fast 4 Barrel
Nitrous Outlet spray bar in the intake manifold
Fueled on E85??? (is this possible?)
This will be going in a auto fbody and we are looking to spray a 200-300. Any of this sound out of whack?
LQ9 Iron Block
PRC 2.5 LS6 Heads
Forged rods/Crank
Single Plane intake
Fast 4 Barrel
nope, that all sounds about right, much like my build. AAbsolutely on the E85, cam I would look into something similar to mine as well, I know Tick has a cam very close to mine with almost identical events that would be perfect.
On the heads, spend some time on the exhaust port that will be the limiting factor
