Do I have the wrong valve seals?
I recently rebuilt my ls1 motor and put ls6 heads on it. The heads came w/ patriot golds and the machine shop going over my engine said they would look over the heads as well. I need to dig and find the receipt but I believe they replaced the valve seals as well.
I've been noticing alot of oil in my catch can(elite engineering) after a 20 min track session and decided this wasn't right. I pulled the plugs today and they all have alot of oil on the threads(none on the electrode though) in addition to some oil pooling at the throttle body. Now clearly I'm having blowby issues, the engine is making good power and the rings are new, so I doubt its a ring issue which leads me to believe something is wrong w/ the valves. I pulled the valve cover as well and noticed the valve seals were blue in color for intake and exhaust as opposed to the different color seals(brown/black) that are more commonly found. Could the shop have put ls1 seals on my heads and are these different from ls6 seals? Could this be causing my oil consumption/blowby issue or are there other issues I don't know about.
I plan on doing a comp test this weekend as well, but I'm fairly certain it will be good since the engine doesnt feel like its low on compression.
I noticed before I put the catch can on that after a hard session there would be blue smoke at startup. I attributed this to blowby accumulating in the intake though and the large amount of oil in the catch can confirmed it.
The engine only has ~200 miles on it, so it is still in its infancy stage but being that this is a track car, I can't really put 500 break in "street" miles on it. My other theory is that due to the large amount of the high rpm engine braking I'm just getting excessive blowby.
and of course I just went to do the comp check and the battery is dead
