tty bolts tolerance
tty bolts tolerance
How many degrees can you go past recommended last 90 degree turn before they break? Reason I ask is I went an extra 45 degrees due to using the first random directions I googled. To later find they were wrong. So I went torque to 22 ft/lbs 90 , 90 then 45 degrees which is maybe 1/8th of a turn. Think it is ok ? Or should new bolts be installed ? Thanks
1/8 th of a turn isnt much to go past. I honestly cant see it making a difference. I turned a head bolt on a junk motor i have 3 complete turns past tight before it broke today.
There has to be a margin of error , because not every bolt will be the same in every engine. But now im nervous and will be replacing them. Its not my engine doing it for someone else. I have arp studs in my engine.
