what's my new compression ratio
The LM7 5.3L truck engines are 9.45/1 and to find out You're compression go to Wallace Racing and go to there engine calculators ,,,,,,,they have at least 150 different calculators for engines and 1/4 and 1/8th mile times gear ratio changes ,,,,,,,,,,etc . You'll be plugging 3.779" bore 3.622" stroke deck height of say .015" combustion chamber size in cc and piston dome or dish ,,,,,,the LM7 has 9cc of dish so that's +9cc,,,,,,,if the pistons were domed you'd plug in minus whatever the # was and the .015 is minus also because the pistons at TDC come out of the hole
The calculator I always use requires a negative number for a dish piston. I come in right at 9.5 CR using 8cc piston dish. I also used 61cc for the heads, technically the 5.3 heads are 61.15cc. Deck height is usually about .006-.008 out of the hole. I just used .007 for this estimate. If everything else is left the same, changing the heads to 58cc gives you "about" 9.83 CR.
http://www.csgnetwork.com/compcalc.html
