5.3 Lack of Oil Pressure at Idle
Hi everyone, this is my first post on LS1Tech! I love all the courtesy and helpfulness i've seen and have been browsing this forum for months. I finally have a question of my own.
About 2 years ago we purchased 2000 1/2 ton Silverado with a 5.3 Vortec. Soon after, we noticed at very low idle (in gear idling) the oil pressure would hit 0. We tried a new oil pump but that didn't help. It soon got to the point that even idling when warmed up it would reach 0 oil pressure. We checked it out with a mechanical gauge, too. We could not figure it out. We ended up buying a junkyard 5.3 for $300 and dropping it in there, and it's still running great.
It is about 1 and 1/2 years later and i want to take it apart and fix the oil pressure loss. I'm planning on dropping it into and older vehicle (fuel injection intact of course!) I was just curious if there was a common problem that caused these motors to lose oil pressure and some things i should look for. Oh yeah, it might be a 4.8 since it was in a work truck, how can i tell? Thank you everyone!
If the motor is out of the truck you can pull the pan off and look at the crank casting number. The block itself should have a 4.8/5.3 cast into the front and rear of it.
12553482 is a 4.8 crank
12552216 is a 5.3 crank
The 12552216 casting was used in various engines including the 5.3, 5.7, and 6.0 engines.
There is plug in the back of the engine with an O-ring if that becomes dislodged or worn it can bleed off pressure.
If the cam bearings spin it can also block the flow of oil.
If the o-ring at the pick up is not correct or gets pinched it could also cause a loss of pressure.
Not enough oil or wrong type of filter can also cause oil pressure issues.
I really appreciate the help. Is the plug you speak of behind the rear main seal cover? I will definitely look at all of the possibilities when i tear it down.
Finally got time and tried to pull the cam and the 3rd cam bearing was flopping around, keeping it in. I think i have found the culprit! Thank you all very much.
