224 cam owners
Old 03-24-2013, 10:30 PM
slow ride 02's Avatar
Default 224 cam owners
How high are you spinning these little guys? Or more so, what do you have your rev-limiters set at? and what rpm are you shifting at?
Old 03-25-2013, 07:10 AM
mark21742's Avatar
My first can was a 220/224 and I was shifting around 6,300 had fuel cut set at 6,500
Old 03-25-2013, 08:20 AM
farmington's Avatar
A4 and have it set to shift at 6000, but putting heads and a SS4000 on soon, will probably raise that when I get retuned.
Old 03-25-2013, 08:44 AM
thunderstruck507's Avatar
Your shift point will vary based on the full combination and the specific cam profile.
A 224 cam can peak at a wide range of RPM based on lobe design, lsa, advance/retard, etc
Old 03-25-2013, 08:48 AM
sweet99ss's Avatar
I shifted mine at 6600rpm and set rev limiter at 6800-6900 somewhere
Old 03-25-2013, 11:57 AM
My pulls stop at 6,700 thats where the limiter is set. Based on the attached dyno sheet. Should I move my rev-limiter up?
Old 03-25-2013, 04:34 PM
99Bluz28's Avatar
Your hp increases less than 5hp between 6200-6700. Id leave the rev-limiter where it's at.
I'd probably shift it around 6400-6500.
Old 03-25-2013, 06:17 PM
Thanks Bluz28,
Thats excatly what I was looking for.
Old 03-26-2013, 07:44 PM
JAY ROD's Avatar
I shift mine at 6400,limit at 6600 car starts to really pull hard at 4500. Its a nice beginner cam, I already want more and its only been in there for a month.
Quick Reply: 224 cam owners
