2001 Formula hesitation
Old 03-24-2013, 11:26 PM
azwildcatLS1's Avatar
Default 2001 Formula hesitation
I just bought a 2001 formula with 82k miles. Everything is stock and it had been sitting for about 1-1.5 years without even starting. When its idle you can see that theres a misfire because the engines shakes a little. I can also notice the slight hesitation mostly on the lower rpms. Considering that it had been sitting for so long what are some of the things that I can check or replace to make sure it runs smoothly? Im new to LS1s so any help will be greatly appreciated.
Old 03-25-2013, 12:13 AM
2000PewterT/A's Avatar
Change all the fluids first thing, that won't fix the problem but sitting that long especially for engine oil is no good. I would check the wire/plugs first since they are the easiest to check, if they are worn out throw on a new set and check the wires also. Thats where I would start, also try to keep refilling the gas as much as you can to help dilute that stale gas that has been sitting in the tank. It very well may be bad cause causing the problem but its not as common as it used to be.
Old 03-25-2013, 12:43 AM
Yeah I figured I should change out the fluids first. I was also looking at the engine compartment today and the plugs on the passenger side look really hard to acces. Any tips on how to make it easier?
Old 03-25-2013, 01:11 AM
Zlow28's Avatar
is it throwing any codes?
Clean the MAF sensor and check for any exhaust leaks.
Old 03-25-2013, 02:32 AM
adamantium's Avatar
Change the fuel filter too.
Old 03-25-2013, 08:56 AM
Well the service engine light is on and so is the low oil light but I checked it and the level is fine.
Old 03-25-2013, 09:00 AM
alexus6798's Avatar
Change oil as soon as possible and do a full tune up. Don't forget the fuel filter and like stated above, clean MAF sensor and check the codes.
atrain59's Avatar
I have bought 2 f bodies and both had a hesitation changed the maf out on both and it went away. That might be your problem also.
Old 03-25-2013, 03:09 PM
Ok I will try to those things in the next couple of days and will keep you guys posted thanks for the info.
Old 03-28-2013, 02:31 PM
OK guys i was able to do the tuneup yesterday and now it runs smoothly. Thanks for the help and now i just need to save up again to start with the modifications.
Quick Reply: 2001 Formula hesitation
