lifter tray bolt -
I would read this before using a hardware bolt, even though it will probably work fine..
https://ls1tech.com/forums/generatio...bolt-hole.html
GM#12551163
GM#12551163
It is a shoulder bolt and not meant to "squeeze" the plastic lifter tray into the block. You need a shoulder bolt, which you can get aftermarket, but not from a local store. If you have one of the GM bolts, measure it and check McMaster-Carr otherwise I would get it from GM.
Doesn't SDPC have any in stock?
Not one dealership in Canada has any, was told they have to order from US.
Jegs etc have a month wait on the bolt (none in stock).
I was hoping not to spend 50 bucks on quick shipment for 4 bolts.
Texas-speed has them on their site, though not sure if they have any on hand.
I was really hoping I could just walk into a bolts supply warehouse type business...
Would the bolt that is used to hold the pickup tube to the oil pump be the same? I dont have any of the lifter tray bolts to compare. (I need all 4).
