LS1 to LS6 PCV conversion
Old 04-11-2013, 10:02 AM
Roarin_8's Avatar
Question LS1 to LS6 PCV conversion
Going to order the LS6 valley cover through SDPC, any other parts that I need?
If so, what are the part numbers? This cover will still be used with an LS1 intake.
https://sdparts.com/details/gm-facto...parts/12577927
Old 04-11-2013, 10:45 AM
It's not mine! woo hoo!
demonspeed's Avatar
You can look in my build thread for what is needed. One can get all the parts needed for $95 out the door from another place...
Old 04-11-2013, 11:09 AM
Roarin_8's Avatar
SDPC is answering my questions now, just want to be sure I get all the necessary parts.
Old 04-11-2013, 11:17 AM
LS1Tech Sponsor
Beau@SDPC's Avatar
Thanks again. If you have anymore questions, feel free to contact me.
Old 04-11-2013, 11:18 AM
Roarin_8's Avatar
Parts list: valve cover plug (12568011), valley cover to intake hose (12594779) and valley cover with built in PCV - aka: 2004 LS6 PCV (12577927)
The Valve cover plug, are 2 in the bag or just 1?
Old 04-11-2013, 11:19 AM
Roarin_8's Avatar
Hey Beau, yeah I'm in 2 places here. Ok so those plugs, 2 quantity or are 2 plugs in 1 bag?
Old 04-11-2013, 11:25 AM
pauls99z28's Avatar
what place is this ?? pm if needed.
Thanks
Old 04-11-2013, 11:30 AM
edwardzracing's Avatar
Just to add to this and try to get confirmation... which blocks require grinding to get the Valley Cover to fit? I know my aluminum '98 required grinding. Anybody else care to chime in?
Old 04-11-2013, 11:31 AM
Roarin_8's Avatar
1998-2000 I believe, I have a 2000. 01 and 02 came with the LS6 intake manifold so that may explain the difference.
Old 04-11-2013, 11:54 AM
demonspeed's Avatar
Thanks
Check my build thread...
ALL LS1 blocks require the cutting. It's really not a big deal -- just be sure to have everything covered up so as not to get metal dust/shavings in the valley -- or all over the engine bay!
I would also highly suggest new manifold gaskets (my preference is ACDelco, but I was in a pinch and picked up Fel-Pro from Advanced when I was in the middle of doing this mod).
Old 04-11-2013, 11:56 AM
Roarin_8's Avatar
Thanks for the pm demonspeed. This was the last of the parts that I needed. And yes you need new manifold gaskets, I got the fel-pro ones also.
Old 04-11-2013, 12:10 PM
demonspeed's Avatar
No problem! That's why I started my build thread -- so I can help give back to this community which helped me a TON throughout the past decade.
Old 04-11-2013, 12:14 PM
Roarin_8's Avatar
I know the feeling
Old 05-27-2013, 09:36 PM
02Z28LS1's Avatar
you could turn out to be lucky like i was and get an LS6 block (if you have an '02 model), which does not require any cutting at all!
click me!
got the parts ordered, they should be here by Friday, and installed this coming weekend.
Old 05-28-2013, 07:03 AM
Roarin_8's Avatar
Nah I have a 2000 and my mechanic finished the cutting
Old 05-28-2013, 09:29 AM
Justhereforinfo's Avatar
Are the ls1 and ls6 motors more likely to burning oil as opposed to a 4.8 truck motor?
The reason I ask, is I will be removing my 4.8 and installing a 5.7 ls1 shortblock with ls6 heads and intake and a custom cam. I currently dont have an issue with burning oil on my 4.8. My 5.7 block is at the machine shop right now, so Im thinking I should have him cut the block before it gets washed.
I guess my questions are:
Must you use this ls6 valley cover when using an ls6 intake?
If not, I assume I might suck more oil through the valve covers (ls1 pcv). Will a simple catch can suffice?
Old 05-28-2013, 09:42 AM
Roarin_8's Avatar
You don't need the LS6 valley cover to run an ls6 intake.
I might suck more oil through the LS1 PCV and yes you can also run a catch can to alleviate the problem.
Old 05-28-2013, 09:57 AM
demonspeed's Avatar
IMO, you've got the engine apart, so now's the time to slap the LS6 pcv system on.
Old 05-28-2013, 10:17 AM
roastin240's Avatar
Is an oil catch can unneccesary w/ the LS6 valley cover? I have both which is why I ask.
Old 05-28-2013, 10:19 AM
Roarin_8's Avatar
Not unnecessary. Since you have both, how much oil has been in the catch can?
Quick Reply: LS1 to LS6 PCV conversion
