ls1 rebuild cam choice
Old 05-08-2013, 07:37 PM
99dsgz28's Avatar
Default ls1 rebuild cam choice
rebuilding a 99 ls1 for my camaro which is a dd. Just wondering if its worth putting a ls6 cam in it or any cam? It will be tuned when its finished but i am not putting a different converter in it. any input is appreciated.
Old 05-08-2013, 07:42 PM
poltergeist 02's Avatar
I would go for the Z06 cam and an ls6 intake. Why not if it's torn down.
Old 05-08-2013, 07:48 PM
99dsgz28's Avatar
seems like the most common thing to do. would the ls1 springs work with that cam? also whats the cost for the cam, i hear a new one from gm is around 115?
Old 05-08-2013, 08:08 PM
badassracing's Avatar
I dont think an ls6 cam will make that much difference. I would put in something like the TR224. It will be a noticeable difference and very friendly on the street. If you went this route you would have to upgrade springs for sure.
Old 05-08-2013, 08:54 PM
Yes, but I don't think there will be much to gain over the LS6 cam without a stall converter.
Old 05-08-2013, 09:02 PM
springer_4's Avatar
I picked up a 1998 WS6 Vert with #6 Rod Bearing spun, I'm doing the same thing complete stock rebuild with a Z06 Cam and LS6 intake and all the other bolt on's. Can't wait for it to get finished, I also debated on the 224 cam but cost wasn't worth it right now....
I say Do what ya got planned, it'll be a great DD
Old 05-09-2013, 12:07 AM
99Bluz28's Avatar
IMO, there's plenty of good cams between the LS6 and 224/224 114lsa, that would probably be a better choice.
It just depends on the intake, heads and exhaust configuration.
Comp Cams, EPS, Crane, Lunati, Cam Motion, there's over 20 cam that I would choose over the LS6, and would work better with the stock stall than the 224/224.
Old 05-09-2013, 05:32 AM
PREDATOR-Z's Avatar
Before choosing consider your options.
1- Do you want a true DD that will last a long time? Choose lobes that will last, like the"Old Man Cam", I mean Hotcam
Old 05-09-2013, 06:19 AM
99dsgz28's Avatar
Well the biggest factor now is money, im trying to keep it pretty low dollar and very streetable
Old 05-09-2013, 07:38 AM
Super Hulk Smash
JakeFusion's Avatar
Hotcam would be a good choice. Works with the stock converter and LS6 valve springs.
Kit runs about $500 with the LS6 Springs and Cam from GM.
Old 05-09-2013, 08:00 AM
LS1Tech Sponsor
Alvin@PCMofNC's Avatar
I wouldn't do a hotcam. It is a underachiever. We have a few we sell to the TBSS crowd that are in the mid 220's that work with a stock converter and even sound off a good bit. A tried and true 224/224 wouldn't be bad either.
__________________
See what's in our shop on Facebook! Customer Build Blogs!
www.pcmofnc.com
Performance Installs - Dyno Tuning - Custom Camshafts & Valvetrain - Remote HPtuners Tuning - Mail Order Tuning & Sales
704-307-4227
Old 05-09-2013, 01:16 PM
99dsgz28's Avatar
500 bucks for a slightly better ls6 cam doesn't seem worth it
Old 05-09-2013, 05:16 PM
yonerhottlt1's Avatar
I agree that there are better options than the LS6 cam out there but as far as price is concerned you can't beat it. I just installed one in a buddy's car not too long ago with brand new LS6 springs for 200 bucks even. And it will work well with the stock torque converter.
Old 05-09-2013, 06:35 PM
99Bluz28's Avatar
With a Comp Cams #54-424-11(212/218 115lsa, lift .558"/.563") and a set of PAC 1218-16 valve springs your looking at $475, add some Manley LS Series Prs and you looking at $575 shipped.
http://www.ws6project.com/user_stor/catalog/valvetrain/
Now if you want a slightly bigger cam then a Comp Cams#54-414-11(216/220 114lsa, lift .525"/.532") with the PAC 1218s for the same price.
Old 05-09-2013, 10:12 PM
PREDATOR-Z's Avatar
Nice cam for DD. I used one back in 00, made good power till 6300 rpm. I used Comp 918s with it for over a year.
Quick Reply: ls1 rebuild cam choice
