speedometer is reading wrong-changed gears
Hi everyone, i put 3:42 gears in, my speedometer is way off....anybody know what i need to do to get it to work right with my new gears? The cheapest route if possible...i dont know what the stock gears are, i did this along time ago....1998 Trans Am LS-1...thanks
^This. You can get a hand held or go to an in person tuner (recommended). Either way, you're looking at $3-400 bucks. Going to a tuner will open up some horsepower and he will.be your best friend later on down the road when you upgrade further.
You could get a Dakota Digital speedo signal converter, ~$95 and wire it inline. I have one, had it for 2yrs and no issues... Plus it's not a one time use. I've adjusted speedo at least three times... Once for different tire size, once for trans signal (T56 magnum uses a different signal) and once for rear gear change.
Tune, psh....
Tune, psh....
