So...I think I broke something
So....last night I decided to take a quick look at my LS1 that I pulled last weekend. Pulled it because I thought I had a spun bearing. I wasn't expecting this:
#8 piston
Still had good oil pressure, even was running strong, just made noise, lots of it.
Last Thanksgiving I bounced off the rev limiter 2 times by accident trying to roll out from a burn out. I missed the line lock release switch and it hit the rev limiter before I could get my foot off the pedal. For 20 mins I thought I was fine and drive it home. Next day I start hearing ticking noise. Thought it was bent PR or stuck lifter. Pulled the heads, had them checked, #4 intake valve had to be turned & seated. Reinstalled the heads, new CM PR, and LS7 lifters. Took it for a test drive, on the second time it got so much worse. Limped the car home.
None of the connection rods feel loose (like it would with a spun bearing). I turn the crank a few turns and didn't see anything hitting the pistons.
I'm stumped.
Cam lobe sheered? Timing chain stretch?
#8 piston
I'm stumped.
Bounced it only twice?! I've launched my car a few times to have it bounce while I try to regain traction. Unless the previous owner was bouncing it like a ball? lol
