LS6 Bore size
LS6 Bore size
Okay I have been trying to figure out what pistons to go with (stock) but every time I find something and try to price match stuff, different bore sizes pop up. Rod length will be the same 6.125" and stroke will be the same 3.622" but for some reason I keep coming across different bore sizes and I have no idea which one is the right one. some places give me the option for 3.905" and others show 3.898" I'm just super confused and it might be something simple I'm over looking but I am so ready to order pistons anyone who can help will get a gold star from me! Thanks guys
okay so what is the difference between 6.125" rods and 6.098" rods? Stock is 6.098" for rod length and bore size is 3.898". Does stock bore pistons work with 6.125 rods? I have 6.125" rods and I am trying to figure out what to attach to them.
No it won't work the stock gm ls1 pistons have the wrist pin low to accomodate the shorter rod.To run those rods you would need an aftermarket piston setup for a 6.125 rod. Stock gm pistons are made for stock rod length. You need an aftermarket piston made for whatever bore your running (3.898 or 3.905) with a wrist pin height setup for a 6.125 rod
I would go with 3.905. Reason being is that the op is gonna need a bore it sounds like anyway and .005 is perfectly reasonable to go to on a stock block the 99-02 ones can even take a .010 bore. Depending on the mileage the bores may have a slight egg shape to them. I'd just go 3.905 and call it done. 3.903 is just a hone
Moderator
With that said, if it's getting torque plate honed, 3.905" is nicer because it gives the operator a little more material to remove when the torque plate is bolted on and the bore is distorted. 3.903" is usually fine, but it is close. If it's a high mileage block I would shoot for the 3.905" piston.
