Time to change spark plugs LS1
I guess I should change them I bought the car used. Don't know when
they where changed last..Car has 90k
So, What tools will I will need to do this? and do I need a lift and change
them with the car in the air?
what's the best way to get to that # 8 spark plug?
I can't even see it..lol
which plugs do you recommend?
stock engine here..2000 Z28
Thanks for your helpl
http://installuniversity.com/ls1/ins...plug-swap.html
I used this write up the first time I did mine. Its not to difficult, but your hands might look like you stuck them in a blender lol
You will need a spark plug socket, two extension and a ratchet. 10mm socket I think to remove coil pack from passenger side. ( the first time I didn't remove anything) and some " geterdone". After your first time it gets easier and better.
I bought a tool kit from autozone. I can take my entire car apart with it other than a crescent wrench and small hammer
Take coil pack off, or atleast up and out of the way, remove the air tube, and theyre pretty simple to change out, i got #8 from the bottom and it was easy. As for the drivers side, theyre very simple and nothing needs to be removed.
I removed the AIR tube, coil bracket, and used a spark plug socket w the swivel end for the entire pass side. The driver side-removed the AIR tube once again, spark plug socket w swivel, followed by various extensions. Most of it is dependent on on the size of your hands. Just set aside enough time incase you run into any issues.
NGK tr55s
spark plug socket
10mm socket
1/4 and 3/8 drive ratchet
1 short 1 long extension and one swivel
I'd recommend some rags and cleaner to clean the wires off as well as some anti seize and dielectric.
Take all but the VERY back bolt out on the passenger side and move the bracket up and out of the way.
Take the EGR tube off the manifold (2 10mm) and move that out of the way
Sitting on your knees on the battery makes it much easier to reach the back two plugs.
On the drive side take unhook the sensor behind the PS above spark plug #1.. No reason to remove the EGR stuff coming from the manifold on this side or the coil packs.
Driver side shouldn't take 20 minutes TOPS. Passenger side takes about 45 mins-1 hour.
Make sure to get a good grip so you don't mess the wires up.
spark plug socket
10mm socket
