Which heads for my goal? 241/243?
I'm currently freshening up an aluminum 5.7 ls1 short block that will be going into my 2003 silverado. I will be using the stock 4l60 trans. The goal for this engine is to make 400/400 at the tires, or very damn near that. It will be used as a spare vehicle to haul surfboards and fishing gear, and to tear some *** around town. No track use, no racing.
The original plan was to use the ls1 short block, and all ls6 stuff on top. That was before I started lurking aroun ls1tech and found out that alot of people are making around the same power level with just a cam in an ls1.
243 heads are not very common to come by in So Fla, because everyone knows they are good heads. I've only found 2 sets so far, priced around $300-$400 and they didnt even have valves.
Im considering picking up a set of 241 heads, if I can still hit my goal. I'll still be using an LS6 instake, and a custom cam.
Without porting or cnc work, how much power will i be sacrificing by using a 241 head, versus the 243?
Are my goals achievable with the stock 4l60e?
Thanks
Thanks
Depends on the dyno. My car w/ Tsp prc 2.5 5.3 heads / Tsp 228R put down 414/387. On a different dyno it could make 430 or more. That was through an m6.
Depends who does the heads. Should be at least 30rwhp to 50 rwhp stock vs ported.
I have no plans on porting either head. I wouldn't trust anyone locally to hand port them, and see most cnc jobs are about a grand. That's not in the budget.
So stock for stock I'm looking at around a 30 hp bump with the 243?
Since I don't own either head at the moment, it would make sense to wait for a 243/799 casting.
Is $280 a good price for a valve job, resurfacing, and to have my springs installed/setup?
I would suggest you start over on your research.
No way in hell would I bother with a 5.7l block in the truck, sell it to someone else and pick up a complete 6.0l for what you can sell the 5.7l shortblock for. The 317s on the 6.0l are equal flow to 243s. The truck intake is so close to as good as the LS6 intake that it would be fairly stupid to **** away the effort and cost of an LS6 intake on a truck. It is the true LS1 intake that is not great the truck intake is good like within a couple hp of the LS6.
I would put a transgo kit with at least a "Vette" servo in the tranny, the 2nd gear servo is smaller than they used in the 90s LT1 cars which were a lot lighter with less power.
Hell I would also say with your willingness to accept less power if you have a 5.3l now put CNC'd heads on it with the truck intake and sell the 5.7l. I would think 350rwhp achievable on a budget that way. Yeah you will spend money on heads but the sale of the 5.7l and not wasting money on a LS6 intake would have you cash ahead of the current plan.
Btw the 241's would be better than the stock 243's AFTER you got um back from the machine shop...close toss up, depends on what you want to do really. Some people are hell bent on 243's so they go that route regardless LOL
Super Hulk Smash
Stock for stock, 20rwhp difference.
Do you already have the 5.7L block? If not, get a 6L block with 317 heads as previously mentioned and mill the heads and run a truck-friendly cam profile. With a 6L intake, some headers, and a cam, with milled heads, you could see 400rwhp with that setup.
If this truck is mainly used for carrying stuff and having fun around town (no street or drag racing), then why do you care so much about how much your engine makes at peak?
Unless you're racing through several gears, power at 6000rpm is going to be almost meaningless. What's going to be more beneficial for you is power and torque under the curve which is where you'll be spending 99% of your time.
I would try not to focus on peak numbers (400/400) and set your goal on the most power and torque throughout the power band. If that only nets you 370hp then so be it, it will be a more fun truck than one that makes 400hp but has shitty power under the curve.
Since another member mentioned the stock truck intake is actually an upgrade from the LS1 intake, I will definately be considering using that instead of the LS6 intake, since it will help keep my powerband more truck freindly.
Far as I know the truck intake wont affect powerband. The "truck parts are for torque" thing get BLINDLY applied to things often. There are two reasons you don't see truck intakes on LS1 cars, one it is TALL and hard to fit in many vehicles, two it is ugly once you remove the cover.
IMO the 5.7l are almost the last of the LS variants I would ever consider, they command a premium price and can't hardly handle an overbore. Heck the newer 4.8l comes with the 243/799 heads. I have debated looking for one as the truck intakes on those are a little better than the one on my 2005 5.3l as well as those obviously being the heads everyone wants.
What did I miss? 400rwhp impossible with a cam and 243s? Call me crazy, but I feel I've seen several cam only ls1 cars in the the 400rwhp range without those heads. Only things I see holding it up are it's an auto, which means you'll need a stall, which means it'll kill any dyno numbers you want to see. Also, I dunno if the ls6 intake will hold you up or not. And you're probably gonna need a big *** cam. My advice is don't even worry about dyno numbers. It is a truck after all.
