Compression/leakdown and fills up catch can after 2x passes
Old 06-29-2013, 10:59 PM
Volatle's Avatar
Default Compression/leakdown and fills up catch can after 2x passes
Motor Specs - ls1 block 347/ diamond high compression dome pistons bore 3.905 stroke 3.622/ t-Rex cam/ absolute speed stage 2.5 5.3 heads "similar to prc". Runs on 116. 12.96 to 1. Issue is I'm getting around 240 average psi on compression test on all cylinders except on cylinder #2 which I got 190psi. Then I ran it to operating temp for a leak down test and decide to see if my compression test would get better or worse. I got 180psi on the same cylinder. Then I did a leak down test on the cylinder and got 8% on it. Should I be worried about this cylinder? The car is untuned and runs on big stuff 3. I'm about to trailer the car the car 6 hours to be tuned and pay around 1k. Main issue with the car is after 2 passes it fills the catch can and blows the oil cap off. I've added pictures of how the catch can was setup and I really don't want to drill/tap these valve covers as they look clean. I've added pictures for suggestions. Appreciate any help, and sorry if its hard to read as I've posted with my cell phone.
Old 06-29-2013, 11:19 PM
427zm's Avatar
I think you've answered you own question by going to this length already to figure out what the issue is. That said, with the variance on #2 you seem to have an issue. If it were me, I sure wouldn't take it for a tune that was going to cost me 1k knowing it had a leak down and compression issue.
Old 06-29-2013, 11:21 PM
Volatle's Avatar
couldn't upload through ls1tech. Here are the images of the catch can setup.
Old 06-30-2013, 12:29 AM
Volatle's Avatar
8% leak down is good....? lol.
Old 06-30-2013, 04:14 AM
therabidweasel's Avatar
Yeah, 8% is nothing too bad. I have a cylinder that is 12% (cold though) and use no oil . Im thinking its got to be something with the catch can setup. I cant tell anything from your pictures. Is that the only line on the can? Where is it going? How is fresh air getting into the case?
Old 06-30-2013, 11:04 AM
Willfulone's Avatar
How is the can plumbed up
Old 06-30-2013, 01:33 PM
Volatle's Avatar
It's just connected to the valley. This thing fills up so fast, after we ran it to operating temp it blew off the oil cap and had about a 1/4-1/2 quart of oil in the can.
Old 06-30-2013, 06:20 PM
Man that is not good. You will blow the most inconvenient seal on any motor like that. At least it always seems that way, LOL.
You need a vent. I think what is happening now is the pressure builds up and pushes the oil into the can. If you vent the filler or preferably both VCs it should help a lot.
Quick Reply: Compression/leakdown and fills up catch can after 2x passes
