Head gasket advice!
Head gasket advice!
Ok I'm in the process of changing a blown head gasket. I have the heads off already so my question is. How do I get the rest of the coolant out of the block? What should I use to remove the residue from the old gaskets? And should I get the heads resurfaced or just cleaned and checked for cracks? Thanks in advance!
Shop vac?
Does the shop vac have to be a certain hp to be strong enough to get the coolant out? Because I don't think I can get to the drain plugs in my car port.
I suppose you could try a siphon tube through one of the holes in the deck surface, if you can't remove the drain plugs.
I would not do a head swap without flushing and changing the coolant.
