Over revved ls1
Old 07-10-2013, 10:17 PM
98KILLACAMSS's Avatar
Default Over revved ls1
Ok so heres the story, I was driving down the freeway, Pulled up next to a challenger n said to myself ima smoke it, so i go into 3rd n smash, then while i was gonna power shift to 4th i hit 2nd, right away i put da clutch in but the car started tripping n turned off, as i was going about 80-100 i had to coast off to the side, the car wouldnt start for about 15-20 minutes, then it finally started, shaky n weird, as i gave it a lil bit of gas to kinda give it more fuel to get it going, i got the ses light, shaky n misfiring cyl 8, i went home took it apart found 3 bent pushrods, replaced em with stock pushrods that i got from my buddy that had jus built his ls1, n turned it on n it still clicks n ticks n shakes a lil with the p0308 code, sumtimes it goes away n sumtimes it comes back, i got no broken valve springs n all the rockers felt the same nothing out of the ordinary, i switch coil plug n wire from 8 to 2 to see if there was a problem there, nothing, so my question is wat might i have damaged if i checked that n replaced da bent pushrods, any ides? Comments? Im extremely upset at myself for this n i would never imagined it happening to me but its done now, i jus wanna repair it....
Old 07-10-2013, 10:20 PM
wildcamaro's Avatar
Might have mangled a lifter...drain that oil and check for needle bearings
Its a 98 camaro ss m6 95k miles drive it up to 3k or 4k every once in a while dont remember the last time i wen wot after this incident, full suspension muffler delete stock engine
Old 07-10-2013, 10:21 PM
wildcamaro's Avatar
I was thing of rockers lol, I meant check for pieces of the roller from a lifter
Old 07-10-2013, 10:22 PM
Mazzenger's Avatar
I would pull the head and check things out.
Old 07-10-2013, 10:23 PM
If i drive it slow n babying it will i damage more stuff? Because i work about 4 miles away from home n i need the car to go to work 6 days a week plus now i gotta buy the parts....
Old 07-10-2013, 11:19 PM
IrbyBocksnick's Avatar
I tried that method with an Oldsmobile 72 Cutlass 442 back in the day. A few miles down the highway it throws a rod and I have motor oil all over the highway. I would trailer that baby and look into the motor before you fubar it. Better safe than sorry.
Old 07-11-2013, 05:48 AM
Busted Knuckles's Avatar
Sounds like the heads gotta come off and lifters out.
DON'T RACE ANYTHING YOU CAN'T AFFORD TO LOSE FOR A WHILE!!!
Old 07-11-2013, 07:19 AM
TheWolfMatt's Avatar
Damn, that sux bud.
My lil bro did this with his first car, an 89 Ford Escort GT. He went from 5th to 2nd on the highway doing about 75, dropped the clutch thinking it was 4th to climb a hill and then started smoking out the back. He said the rpms went through the red and that was it, right around 7500rpm or so and then lots of smoke. He towed it home and I removed the head off it and found the #2 piston was missing, must have broke loose and found a new home in the oil pan below, we sold it for scrap the week after for 1k. Funny though, he only got it for $200 cash.
Old 07-11-2013, 09:28 AM
boostit5.3's Avatar
the throttle stuck on my 351w foxbody one time and i over reved the crap out of it. heres some pics of the carnage i got away with just replacing a few of the valve keepers....
Old 07-11-2013, 09:45 AM
RockinWs6's Avatar
The timing chain my have jumped over a tooth and caused this damage, be sure to check it.
Old 07-11-2013, 10:21 AM
2000ultraZ1911's Avatar
I think I'd try n find a ride to wrk maybe ask someone you wrk with. Things are only gunna get worse even if you baby it. Park it pull the heads go over the top end and take it as a learning experience.
Old 07-11-2013, 12:03 PM
zzcamaro00's Avatar
probably bent a valve, probably damaged the lifter as well from being smashed from the piston.
Old 07-11-2013, 12:12 PM
The Scammer Hammer
dr_whigham's Avatar
1998 Camaro?
How's the oil pressure. There's a good chance you stretched one, or several rod bolts...
Old 07-11-2013, 01:25 PM
mkvamso's Avatar
Id start by pulling a valve cover
Theres a good chance it broke a spring, bent a pushrod, or a rocker puked out the needles.
Id look there first before i started tearing it down
Old 07-11-2013, 01:28 PM
wildcamaro's Avatar
Like ultraz stated earlier park it and get a ride with a coworker or hop on the bus...you don't wanna do more $ in damage...and word to the wise always have a back up car if your out racing ur camaro bc they always wanna break when you don't have a backup...in retrospect its only going to cost the price of some head gaskets and head bolts to pull the top end and see what you working with...
Old 07-11-2013, 01:30 PM
wildcamaro's Avatar
Oh yea and bozzhawg that's the only way a mopar can beat a Chevy is if it breaks or has a questionable driver lol
Old 07-11-2013, 03:34 PM
I agree wildcamaro no mopars in are town worth talking about...Mostly.Old.People.And.Rednecks!! MOPAR!!
Old 07-11-2013, 04:56 PM
Pfadt Racing's Avatar
Maybe time to pull the heads and have them worked?
Old 07-11-2013, 05:06 PM
ZHAWK154's Avatar
I did this except from the top of second into first gear, instead of third. Intake valve ended up kissing piston and cracking it. Ill bet you might see the same damage prob worse bc you were going faster. Keep us posted!
Quick Reply: Over revved ls1
