Car doens't start sometime?
I have a problem, my car won't start at times. When you turn the key on everything comes on, but when I try to start it noting happens.
I will play with the negative wire on the battery, and it will start sometimes. if you hook it up to a battery charger and it will fire up other times. Most of the time it starts and runs great, there are just some times that it wont.
The battery is new
Wires on the battery are tight
After a few min it just starts up.
May only do it once a month or so.
I am sure there is a short somewhere or something is not ground right, just woundering if anyone has any ideas for me?
The battery is new
does your car have long tubes or shorty headers? i had a customer with that intermitten starting issue and it ended up being the starter wire that had shorted to the shorty header. if not remove your starter and take it to get it tested. or just test it at home.
I had a somewhat similar problem, car would crank but not start. Turned out to be the ignition relay. The starter relay and the ignition relay are the same, just switch them around and see if the problem moves with that relay. I think I paid less than $10 for a new one. Good Luck!
The car is bone stock right now, I have the Long Tubes but i want it to start everytime before I put it them on.
