Yet another push rod length question
The engine is a stock bottom end 5.3 with 212/218 highlift cam, headsmilled .030, 5 angle valve job, stock valves unshrouded, using stock head gasket. I found zero lash between 7.225 and 7.25. Took 7.25 and added 0.090 for preload and came up with 7.34 closest rods I found was 7.35. I checked my work by dropping in the checker at 7.35, tightend the rocker down till I had no more endplay and then counted the number of revolutions till the rocker bottomed out on the seat (1.25 rev). Does this sound ok?
