Tsunami Camshaft
Old 09-05-2013, 11:48 AM
TruckerBomb's Avatar
Default Tsunami Camshaft
Found a good deal on a tsunami camshaft. I'm new to building motors, so I'm here to ask some guidance.
I've got a 5.3 lm7. Will it fit? What other mods/parts will be required? Is it good for a boosted motor? I do plan on adding a turbo.
Thanks in advance!
Old 09-05-2013, 12:03 PM
65ChevyIINova's Avatar
It should work, the 5.3's can use the same cams as LS1/LS6. but with that much lift you will need to replace your valve springs. That much lift will be too much for stock springs.
Old 09-05-2013, 12:19 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
It will fit but thats way too big of a cam for a 5.3. Go with something in the low 220 range.
Old 09-05-2013, 12:29 PM
Wink
What are the negative affects of using the tsunami? Could they be compensated for by other mods?
Old 09-05-2013, 12:39 PM
2000PewterT/A's Avatar
A Tsunami in a 5.3 would be a overkill, the cam simply tries to move more air than the 5.3 can take in and out, and its not really a boost cam, its more of a max effort cam. A 220-224 range cam would suit your engine much much better.
Old 09-05-2013, 12:47 PM
Ok, thank you.
I apologize for my newbness. I greatly appreciate the advice though!
Old 09-05-2013, 01:00 PM
Unless this was going in some insanely light vehicle you are going to find yourself without much lowend power. The tsunami is a good cam and we have made some big numbers with it, but it simply wont act the same in a 5.3. The 5.3 just doesnt have the displacement to move enough air. As stated before it would also be a poor boost cam.
Depeding on what you are doing with this motor I would really look into something in the low 220 range.
Old 09-05-2013, 02:00 PM
I went with a comp cam with around a 220 duration and 560 lift. Gives a broader power range from 1500-6500
Old 09-05-2013, 02:14 PM
munn79ta's Avatar
tsunami cam is pretty sick my buddy has one in his 02 z. not for boost tho...
Old 09-05-2013, 11:24 PM
what about the ls3 cam out of a c6 corvette? Will that fit in the 5.3? or are the gen 4 different?
Old 09-06-2013, 06:11 AM
masterz28's Avatar
They are different
Old 09-06-2013, 08:02 AM
vettenuts's Avatar
There was a recent thread on camming a 5.3 and also a recent article in Car Craft (which is referenced in the recent thread). There was a lot of good information in that thread if you can find it. It was within the last couple of weeks.
Old 09-06-2013, 09:58 AM
Thanks, good read. I'll keep looking elsewhere then.
Quick Reply: Tsunami Camshaft
