Clean Cylinder head valves. Anyone try this?
Old 09-19-2013, 03:12 PM
Knine00's Avatar
Default Clean Cylinder head valves. Anyone try this?
Has anyone tried this? I am about clean my valves and want to find the best way to clean them. Would this be safe?
Old 09-19-2013, 03:26 PM
The_Bishop's Avatar
NOOOOOO.
Gentle wire-wheeling. If there are a lot of deposits, I have had luck with soaking the valves in Pine-Sol overnight.
Scotch-brite is abrasive, moreso than a wire wheel, and can damage the seating surface. Scotch-brite on the valve stem is bad news, too.
Old 09-19-2013, 04:01 PM
Decadence75's Avatar
Soak them in a concentrated degreaser overnight and if there is anything left on it after that some brake cleaner and a good rag.
Old 09-19-2013, 06:00 PM
Gunslinger09's Avatar
Yep.
You can get carb parts cleaner in gallon paint cans that have a wire basket inside. Load the basket up with the valves and soak over night and call it done. I wouldn't risk messing up the face of the valve or the stem by doing that.
Old 09-19-2013, 06:09 PM
RonSSNova's Avatar
Valves are hard, just use a wire wheel in your bench grinder
Old 09-19-2013, 06:17 PM
Knine00's Avatar
Wire wheel wont hurt the angles?
Old 09-19-2013, 06:29 PM
Nope.
The wire is softer than the steel of the valve.
Old 09-19-2013, 06:36 PM
Knine00's Avatar
So I wont have to lap the valves? Also, will a brass wire wheel work?
Old 09-19-2013, 10:25 PM
RonSSNova's Avatar
If all you have is brass, sure. And as was said, it won't hurt the valve face. I've even looked at them with a microscope....
Light lapping is a good idea no matter what, unless it's a fresh valve job.
Ron
Old 09-19-2013, 10:39 PM
xRaTeD's Avatar
Looks safe to me i wouldn't do the stem though lube with the red pad has got so be equal to 600 grit
Old 09-19-2013, 11:00 PM
JudgeGuns's Avatar
Thumbs up
lol
Old 09-20-2013, 08:55 AM
thunderstruck507's Avatar
depending on how cautious you want to be, they sell a decent sonic cleaner at Harbor Freight now for like $80. I've seen people use it to clean guns and it works well.
The following users liked this post:
Homer_Simpson (09-10-2023)
Old 09-20-2013, 09:08 AM
Pony Exp.305's Avatar
agree with Thunderstruck said..
Old 09-20-2013, 09:31 AM
s14kouki's Avatar
Buy new ones =D j/p man. Just leave them soak in a heavy duty degreaser overnight and clean them with a rag in the am.
Old 09-20-2013, 10:30 AM
wildcamaro's Avatar
I dial my valve cleaning like that, except I use a drill press instead...as long as you are confident enough to stay off the seat it's not a problem. Also tape the stems up with a few layers of thick masking tape so you don't mar the surface of the stem....I like to start with emery cloth or 120 grit and then work my way up to 320 or so...I would stay away from a wire wheel though, I've never tried it to disprove it but I won't be trying that anytime soon...
Old 09-20-2013, 11:20 AM
KCS
Moderator
KCS's Avatar
I've used the wire wheel, works just fine, especially for the OEM valves. With the aftermarket stuff I'll even chuck them up in a drill and use green scotchbrite afterwards to polish them up a little bit.
It's important to clean the seat face really well and inspect for any pitting or nicks. It wouldn't hurt to take them to the machine shop to grind in a new seat and tip in the valve stem.
Old 09-20-2013, 12:00 PM
speer13's Avatar
The method done in the video is fine. It was done on Titanium valves which come standard in those race bikes but would work for all, pro-circuit kawi is a top team won multiple championships and I can't see them doing something that would hurt performance of their bikes.... plus people remember our valves are high grade steel, stainless, inconel or titanium not a soft material likealuminum so using a soft wire wheel or scotchbrite pad is not going to hurt them if done carefully. As others have said inspect the valve seat area after it all anyway to be sure and run it..... I have seen and done far worse to valves at the track in a 1500hp racecar to make a round and end up fine...
Old 09-20-2013, 07:59 PM
Knine00's Avatar
Thanks guys. Wire wheel worked great. I lapped the valves just for security!
Old 09-20-2013, 08:18 PM
redtan's Avatar
Man what kind of gunk do you guys have on your valves that you need to do all that harsh cleaning on wire wheels? If so, you got bigger problems on your hand than how to clean the valves.
Maybe it was just me, but my valves were almost spotless when I took them off after 98k miles. A 2 minute soak in brake cleaner and a light wipe with a rag and they were shiny again.
Old 09-21-2013, 03:37 AM
RockinWs6's Avatar
The quick cleaning method in the video was perfect, I'd do it.
Quick Reply: Clean Cylinder head valves. Anyone try this?
