Head gasket bore size
Old 10-03-2013, 08:49 AM
ihdude's Avatar
Default Head gasket bore size
Building a 408 with AFR heads. On the head gasket I'm wanting to run a .040 thickness. What bore size of the gasket should I run?
Old 10-03-2013, 04:22 PM
RezinTexas's Avatar
measure your cylinder bore and head combustion chamber width. Then get a gasket bore that is at least 0.020" bigger than the larger of those 2 measurement.
Old 10-03-2013, 05:09 PM
Dmoney's Avatar
I use a .040 thickness 4.06 bore Cometic gaskets on my 402. A friend of mine uses a 4.085 on his 408.........
Old 10-03-2013, 10:37 PM
2000PewterT/A's Avatar
x2 This is what I do also.
Old 10-04-2013, 04:58 PM
Russ K's Avatar
Same here, but I use a gasket bore the same size, or just the next size larger. Cometic lists 4.040,4.060 then jumps to 4.100.
Russ Kemp
Old 10-04-2013, 05:53 PM
The Scammer Hammer
dr_whigham's Avatar
I believe AFR specifies what size gasket to run with their head. A lot of times it's larger than your bore.
Old 10-06-2013, 04:39 AM
moosifer's Avatar
I run the ls9 gasket on my 408 (4.030 bore).
Old 10-06-2013, 05:31 AM
RezinTexas's Avatar
AFR makes great heads, however I would not take their direction on gaskets. They told me to us a 4.135" bore gasket with my 210 heads (which have a 3.96" cc width).
Old 10-06-2013, 06:45 AM
The Scammer Hammer
dr_whigham's Avatar
I know. It seems they always tell folks to go big on the gaskets, and I've never understood why. You think that "dead spot" would just pack with carbon and create detonation... There has to be some reason why they say that though?
Quick Reply: Head gasket bore size
