Can somebody pick me a cam? PLEASE!!
Old 10-16-2013, 06:41 AM
Trannysgonewild12's Avatar
Default Can somebody pick me a cam? PLEASE!!
Im looking to get a cam that i can use the stock stall on and im wanting to go with z06 springs and different pushrods. i want a cam that chatters to tho so can someone help me?
Old 10-16-2013, 06:43 AM
http://www.hawksthirdgenparts.com/pr...-Camshaft.html
would i be able to use this cam?
Old 10-16-2013, 07:13 AM
PREDATOR-Z's Avatar
You could use the 114 but you'll need better springs than Z06 springs, like PAC or PSI.
If you are set on Z06 springs then GM 'Old Man cam'
Old 10-16-2013, 01:34 PM
mjs1012's Avatar
I wouldnt try running the 228r on a stock stall like you linked to.
Old 10-16-2013, 02:00 PM
Russ K's Avatar
And I wouldn't want an XER lobe (noisy)
Russ Kemp
Old 10-16-2013, 02:03 PM
PREDATOR-Z's Avatar
Russ Kemp
There are other good lobes available but if installed correctly with proper supporting parts, they can be quiet.
Old 10-16-2013, 04:20 PM
i dont want it to be quiet lol i want that mean sound
and what about this cam on the stock stall?
Old 10-16-2013, 04:23 PM
can yall show me a cam i would be good on a stock stall with?
Old 10-16-2013, 04:27 PM
thunderstruck507's Avatar
you should invest in a good stall converter before you swap cams in the car unless the sound is all you care about
Old 10-16-2013, 04:44 PM
Fry_'s Avatar
Do a search on cams and stock torque converters you'll find that no one with any experience thinks it's a good idea. I'd say the most recommended converter would be a 3600rpm Yank SS. Also you may want to stop posting links to non sponsor sites, your going to **** off the mods.
Quick Reply: Can somebody pick me a cam? PLEASE!!
