Metal flakes in oil pan, low oil pressure. Input needed.
Old 11-08-2013, 11:33 PM
Pollo432's Avatar
Default Metal flakes in oil pan, low oil pressure. Input needed.
Ok guy so a couple months ago I installed a forged 370 from a local engine builder. Ran the truck for about a week and it started loosing oil pressure. Changed oil and found cooper metal flakes in the oil pan. Cleaned pick up tube screen and put everything back together added thicker oil. Still no oil pressure, so parked the truck. Today I took the engine out. Tore it apart but could find nothing wrong. I have it tore down to the short block and can't see anything wrong except the oil pump is a little tight to turn. Any ideas would be greatful. Truck is turbo'd can't see anything wrong with the turbo.
Old 11-09-2013, 12:01 AM
ls1 1990 VN's Avatar
Whats wrong! Is it possible the local engine builder is not LS savvy, bearings now trash?
Old 11-09-2013, 12:20 AM
Pollo432's Avatar
I doubt it. He's pushed a couple of guys into the 10s in 4600lb trucks. Careless? Possible. I will tear down further in the AM.
Old 11-09-2013, 12:50 AM
Pollo432's Avatar
I will take main caps and rod caps in the morning and check back.
Old 11-09-2013, 02:05 AM
You say he's pushed a couple of guys into the 10s....You didn't say they were LS powered & he had built them the motors
Old 11-09-2013, 07:13 AM
Pollo432's Avatar
Yes LS motors. And he's a one man operation, I'm pretty sure he built the engines.
Old 11-09-2013, 07:51 AM
Gray86hatch's Avatar
Check the thrust of the crank first
Tim
Old 11-09-2013, 08:39 AM
Pollo432's Avatar
How much should the thrust be. It shouldn't move much correct?
Old 11-09-2013, 08:54 AM
Super Hulk Smash
JakeFusion's Avatar
+2 on the thrust. That happens even to the best builders sometimes.
Old 11-09-2013, 09:43 AM
Pollo432's Avatar
Thrust is nice and tight. I can't see any issues with the short block. It spins good no visible damage. All bearings seem to be in tact. Would hate to rear down short block and nothing is wrong.
Old 11-09-2013, 09:58 AM
Super Hulk Smash
JakeFusion's Avatar
Was the o-ring pinched in the oil pump? If so, that would show up as low oil pressure. And the flakes would be bearings starved for oil.
Old 11-09-2013, 10:53 AM
Pollo432's Avatar
O-ring looked good. Ill give it a one over. Got called in to work. Once I get back ill tear into the mains.
Old 11-09-2013, 11:07 AM
RockinWs6's Avatar
You sure all the oil gallery plugs are in place and didn't move? Cam bearing walk? Relief valve in oil pump stuck open?
Old 11-09-2013, 11:12 AM
The_Bishop's Avatar
Cam bearings?
Old 11-09-2013, 11:36 AM
Pollo432's Avatar
That was my first guess but after pulling the cam, bearings look fine slight scratches but nothing serious. Cam looks good.
Old 11-09-2013, 04:12 PM
Pollo432's Avatar
Mains are toast. I'm goin to blame it on the oil pump. Seems like it wants to lock up.
Old 11-09-2013, 04:14 PM
Was the pump aligned when it was installed.
Tim
Old 11-09-2013, 04:33 PM
Pollo432's Avatar
Yes it was.
Old 11-09-2013, 07:15 PM
Pollo432's Avatar
Melling high pressure, break in with 5-30 and then tried 15-40
Old 11-10-2013, 02:07 AM
Burken01's Avatar
I don't like seeing stuff like this especially since im a few weeks out on starting my new engine..
Sorry to see this..
What does your engine guy think?
Quick Reply: Metal flakes in oil pan, low oil pressure. Input needed.
