Cam and Head question from a newb..
Old 11-19-2013, 07:05 PM
LS Caballero's Avatar
Default Cam and Head question from a newb..
OK, I recently acquired an LM7 motor with approx 90k miles and I will be swapping it into a 1984 gmc Caballero. I will be having the block cleaned and honed.
I have the opportunity to get a set of 243 heads that have been ported and polished and a cam with the following specs- .588/.595 intake/exhaust lift, 228/232 duration on a 114 lsa.
Would this make a good combo combo for a carbed build?
I am also able to get a 4l60e tranny that has been mildly built and am wondering what issues I may run into with the install or should I just go old scholl and drop a th400 in?
As a side note I am trying to do this build as economical as possible.
Thanks in advance for a helping a newb!
Old 11-19-2013, 09:56 PM
A.R. Shale Targa's Avatar
That cam has been a proven performer in 5.7-6.0 engines and although not
ideal for your 5.3...if it's a good deal you could use at least a 3600 stall
converter in the 4l60 trans and it should run out decent if the carb is tuned
properly.
Old 11-20-2013, 06:55 AM
what would be a good cam for a set of ported and polished 243 heads then?
I am getting a pretty good price on the heads so I don't mind spending some extra for a cam that would be ideal for the 5.3.
Old 11-20-2013, 09:17 PM
It's not the heads but rather the carb and short runner intake that usually
requires a bit different specs on the cam. You have plenty of choices here...
Geoff @ EPS, Texas Speed, Martin @ TICK performance, Ed Curtis, Brian
Tooley, Alan Futral...take your pick, make a few calls, and spend your money
how you want...You WILL be happy with anyone of these choices.
Quick Reply: Cam and Head question from a newb..
