main caps
main caps
please forgive me if there is already a thread on this, but i am in the process of rebuilding my short block and was curious if i should get a set of billet mains with the dowels. its not a super high horsepower engine, im hoping for a little over 500 at the crank but i do have plans for some boost in the future but not a lot since im going to have a compression ratio of 11.1:1. i already have mahle forged pistons, and scat h-beam forged rods, but i have the stock crank. down the line im thinking i should get 650 respectivley with boost/tuning/ect, so the question is...are billet mains worth it?? i already have arp main stud kit, and i will be using either clevite or callies coated main bearings. is there anything else i should take into consideration in the short block, i already have a billet double roller, melling hp/hv oil pump, stock pan, pick up, and windage tray/baffle. i looked at girdles also but im not making a 1000hp so i dont know if that will be worth it also. if you have any experience in building high horespower ls based engine, etc, please help me, this is only my 3rd build and my last one was 478 at the crank, i just need some suggestions on what route to go for insurance.
Oh OK, that's going to save some money because they look and sound like good ideas, but I wouldn't know since I've never used them in my own personal builds. Thanks for the input, but what is pinning the caps? II've never heard of that before, would that be good extra insurance or just still not worth it? My entire build is with ARP bolts/studs and fasteners and iI'm just looking for all that extra bottom end insuranc tthat i can find. Thanks
Like I said arp main studs and head bolts/studs and your good to go..
