what are some good roller rockers out there?
Old 11-24-2013, 09:15 AM
SStressin's Avatar
Default what are some good roller rockers out there?
I have a set of yella terras currently. been reading more and more how they are heavy etc. what is a nice light set out there that dosent fail and dosent cost over 1000 dollars. saw the comp pro, comp gold or the Harland sharps
Old 11-24-2013, 09:54 AM
garygnu's Avatar
stock gm rockers with a compcam trunnion bearing upgrade .they work great heads with powder metal guides .
Old 11-24-2013, 09:58 AM
96capricemgr's Avatar
Probably none if you want full roller.
Do you have bronze guides? If not stock with a trunnion upgrade is pretty much where it is at, even according to most vendors.
Old 11-24-2013, 10:31 AM
SStressin's Avatar
I have trick flow cnc 225s. Cant go with stock rockers with truion because i have a .650 lift cam. Heard stockers start ruining **** above .630 lift
Old 11-24-2013, 10:47 AM
64post's Avatar
Beware, some aftermarket rockers.
Old 11-24-2013, 10:51 AM
Having PM guides put in the heads is likely the most effective solution you have available.
Old 11-24-2013, 06:11 PM
soundengineer's Avatar
Jesel...best you can get...available in single or double adjustable.
But you will have to either use valve cover spacers or buy tall valve covers.
Old 11-24-2013, 06:29 PM
How much you in once you spend over his $1000 price point plus valvecovers?
Old 11-24-2013, 08:50 PM
ejbta2's Avatar
I have been running comp pro magnums 1.75 for a couple years. They did fine with a stock cam but when I put in a cam the problems started. I broke a locking nut, and a couple weeks later broke another. I also broke a BTR max pressure valve spring. I put my stock rockers with the comp trunion upgrade, my problems stopped. Most engine builders and tuners will tell you ls engines do not need roller rockers, this is not an old 350. Stock rockers are proven performers. I learned the hard way. Almost lost an engine when the locking nut broke at 6500 rpms.
Old 11-24-2013, 09:24 PM
Coonass350's Avatar
Dammit man..
Old 11-24-2013, 09:42 PM
Originally Posted by Coonass350
Dammit man..
Stock rockers are only good to about .600 lift...
Beyond that they start to tear up valve guides....especially the brass ones.
You really need to go to an adjustable roller rocker once you start going past .600 lift
Old 11-24-2013, 10:45 PM
Super Hulk Smash
JakeFusion's Avatar
.630" is the recommended limit for stock rockers, though plenty of people run much more than that.
.630" is the limit because of scrubbing at the valve tip, not the valve guide.
For the guides, you need Powdered Metal guides, or stock geometry and bronze guides in order to run stock rockers. GM castings come with PM guides, which last forever it seems. Bronze isn't much of an upgrade it seems. It just wears faster, especially when the geometry is changed. On heads with altered geometry, it occurs with BOTH roller rockers and stock rockers.
Old 11-24-2013, 11:20 PM
yota's Avatar
Interesting advice in here, considering everyone told me not to run my Harland Sharp adjustables in my valvetrain thread with over .620" lift on my cam and to run trunion upgraded stockers instead. Watching this to see where it goes.
Old 11-25-2013, 02:47 AM
ls1 1990 VN's Avatar
Listen to what we told you in your thread!
Your mods are not that different than mine & the H/S rockers caused me grief till I went back to OEM rockers.
Old 11-25-2013, 04:20 AM
vettenuts's Avatar
The YT's are pretty light as far as roller rockers go. If you don't have the newer design (Gen III) and are running heavier springs, here is my input.
Replace your older design YT rockers (assume this is what you have) with the newer design for around $400+. Then verify your rocker shim to obtain the narrowest wipe pattern you can get, which may require shims other than provided by YT with the rockers. Last, once shimmed measure for pushrods and put in the largest OD pushrod you can fit. This will help eliminate valve bounce and the resulting shock loads to the rockers at high RPM.
There is more to rocker life than just strength, the geometry and valve train stiffness play a very important role as well.
Old 11-25-2013, 07:49 AM
SStressin's Avatar
do you know what year they switched to the new design? and I have trickflows so using a 3/8 pushrod. also I have ferrera stainless valves. I was thinking bout going to turnd down ls3s. good idea?
Old 11-25-2013, 08:09 AM
ckpitt55's Avatar
It was late in 2010 I believe.
Old 11-25-2013, 08:22 AM
Super Hulk Smash
JakeFusion's Avatar
I'd still put the PM guides in there. The heads I was talking about with different geometry was the TFS heads. They show wear even with roller rockers per Brian Tooley as seen here https://ls1tech.com/forums/17836424-post11.html. Which is why he recommends PM guides and stock rockers.
And get the turned down LS3 valves. The difference in weight is 110g vs 83g on the 2.04" intake valve.
Old 11-25-2013, 08:35 AM
SStressin's Avatar
so stock heads come with pm guides? if so I have a set of stock heads laying around can I pop them out and use em? or buy new pm guides from trickflow?
Old 11-25-2013, 08:50 AM
KCS
Moderator
KCS's Avatar
How is the geometry changed?
Quick Reply: what are some good roller rockers out there?
