Digital Torque Wrench
Get a jump on your Holiday Shopping and get our Digital Torque Wrench w/ Blow Molded Case for $99 - including shipping. Just go to our website: Brown Line Metalworks, LLC | Professional Grade Digital Torque Wrench and click on the "Buy Now" button. At checkout, enter the coupon code: LS1Tech
You can see the torque wrench in action in the following video:
Product Specifications
Patented Double Gear Sensing System
Designed, engineered, and tested by Brown Line Metal Works, the patented* D.G.S.S. technology ensures repeatable accuracy of +/- 3.5% both clockwise & counter-clockwise
Accurate from 20 – 100% of full scale (7% accuracy from 10 – 20% of full scale)
Microprocessor Controlled
8-bit electronics ensures accurate readings and simplicity of use
Allows for both Peak and Track mode
Individually calibrates each wrench
Supplies unique serial number for each wrench
Ratchet Head
1/2" drive reversible ratchet
32-tooth gear provides an 11.25º arc while handling high torque loads
Forged from Chromium Vanadium alloy to ensure strength
Conforms to ASME B107.10 2005 standards
Range
15 – 150 ft/lbs
180 – 1,800 in/lbs
20.3 – 203 Nm
Digital Control
Large backlit digital display shows both target torque and current read-out
Intuitive button design makes operating torque wrench simple
LEDs and digital display provide visual feedback when operating wrench
Buzzer creates audible feedback when target torque is reached
Easily switch between ft/lbs, in/lbs, and Nm
Automatically powers off when not in use for 2 minutes
Low battery indicator
Handle
Soft-touch overmold provides comfortable non-slip grip
Engineered plastics ensure an impact resistant housing
The offer is valid until January 15th, and is only for the lower 48 states.
The following users liked this post:
Homer_Simpson (03-12-2023)
i have two Snap-On digital torque wrenches and i love them. i have a 3/8 that does In, Nm, and Ft lbs. and i have a 1/2 that does those and degrees which is very helpful in torquing Ls heads. i can have a set of heads installed and torqued to spec in about 15-20min.
You can read more about it here:
Professional Grade Digital Angle Gauge | Brown Line Metalworks, LLC
It was recently named by Motor Magazine as one of the Top 20 Tools of 2013. You can read the whole article here:
Motor Magazine Top 20 Tools of 2013
You can purchase it online at:
Toolsource and Sears
BLMW
We have had a few customers tell us that they had trouble getting our shopping cart to work, so we are going to keep the discount code active for a few more days. If there are any problems, please email us at info@brownlinemetalworks.com
Thanks.
BLMW
Thanks.
BLMW
That's MISTER MODERATOR
Brownline, while I'm certain your wrench is every bit as good and accurate as you say it is, I would gladly pay more for it if it was US made. It does look like a very nice product.
You posted this thread just as I was about to need a digital torque wrench for an upcoming engine project.
After much consideration, I chose to purchase a US made torque wrench.
We send far too many jobs and money to foreign countries and given the opportunity to buy Made In USA, I do so.
