Heads and Cam advice
Old 12-15-2013, 04:59 AM
4kiro's Avatar
Default Heads and Cam advice
Looking for advice on a heads and cam build I am starting. My car is a 2000 Camaro with 80k miles. The car had a Procharger on it but it’s off now. I am planning on just doing a heads and cam build. Parts I have on the car are LS6 intake with Deka 60lb injectors. FTP 104 air intake and off-road headers, cat-less y-pipe and flow-master mufflers. Car has an aftermarket fuel pump and aftermarket clutch. I was planning on sending my 241 heads to AI and have them match a cam for it. I want something bigger than a 228 but not as big as a MS3. My car is not a DD but I only drive it on nice days. Any advice is welcomed.
Old 12-15-2013, 05:43 AM
cobalt964's Avatar
depends on your budget I suppose. you can get some really nice hp/tq out of heads and cam tune swaps depending on how much you want to spend.
Old 12-15-2013, 09:03 AM
07bluelbz's Avatar
Just have to ask. Why did you remove the Procharger?
Old 12-15-2013, 09:29 AM
red fury's Avatar
Get the best heads you can afford...AFR,TF, MAST then have the cam built for the heads. I am sure you know a Fast intake will really help out too. 1 7/8 headers ect....
Old 12-15-2013, 10:40 AM
HCI2000SS's Avatar
Look into a Torquer 2 cam if you want something in between the two cams that you mentioned. I had that cam on my previous setup with my PRC 5.3 heads and it was a good match
Old 12-15-2013, 11:01 AM
garygnu's Avatar
check out a TSP head /cam combo ,mite get them on sale for Xmas .are you keeping the current injectors ,or getting smaller ones ?
Old 12-15-2013, 11:18 AM
RedDeadG8's Avatar
those injectors are overkill for this build. send the heads off for porting etc and get a cam to spec, maybe something in the low 23x's.
Old 12-15-2013, 11:24 AM
BrntWS6's Avatar
Go bigger on the cam than you think.....with good tuning now days you can make big cams drive close to stock. I personally wouldn't spend the cash on premium heads....plenty of guys making great power on worked LS6 heads and its a 1,000 difference.
Old 12-15-2013, 08:36 PM
4kiro's Avatar
Thanks that's great advice. Budget I don't want to spend that much money on AFR. I think I'll find some 243 in good shape and maybe have them cleaned up. I sold my kit to fund a turbo build on a roller I picked up. What heads and cam would it take to beat a TA using 227 PRC heads and a MS3.
Quick Reply: Heads and Cam advice
