oil weight
oil weight
Building a 6.0 and need suggestions on what oil weight to run. Rod bearings have clearances of .0022 to .0025 and main bearings of .0021 to .0024. I will be using a Melling oil pump 10295 and i live in south georgia where it is mostly hot. Thanks
That's MISTER MODERATOR
THIS^ Reach for a Mobil1 extended, Wix/CarQuest, Hastings, K&N etc. filter.
And NEVER use any additives. Oils are carefully blended & tested by their makers-don't ruin it with other junk.
Don't know why anyone would run 15w40 in a LS platform. I run that in my Gen 1 juice engine but I build it with some loose clearances. I'm guilty or 10w30 when it gets hot in the LS but 5w30 would probably suffice. BTW, I use Mobile 1 & Wix gold filters.
