where to buy an EASY OUT???
Old 05-09-2004, 10:52 PM
dvandentop's Avatar
Default where to buy an EASY OUT???
damn crankshaft bolt broke about 1 inch of the bolt off in the crankshaft!! already have hold drilled through bolt let in the crank just need to get an easy out
anyone know where to buy an easy out and cost as well???
new longer bolt and longer bolt that broke off in crank!
Old 05-10-2004, 12:37 PM
HITMANSS's Avatar
Sears.
Old 05-10-2004, 12:39 PM
dvandentop's Avatar
what kind of drill but would you guys reccomend as well
Old 05-10-2004, 12:42 PM
HumpinSS's Avatar
Get a left handed cobolt drill bit. It will take the bolt out way easier than the easy out
Old 05-10-2004, 12:43 PM
dvandentop's Avatar
think they have those at sears? if not then where?
Old 05-10-2004, 12:46 PM
HumpinSS's Avatar
Your local hardware (ACE, ACME) should have them but i am pretty sure Sears have them also.
Old 05-10-2004, 12:51 PM
2xLS1's Avatar
I'll bet a $25 pulley install tool delivered to your door is looking pretty cheap right about now.
dvandentop's Avatar
already have a small hole drilled through with cheaper bit, so i guess reverse drill bit will extract and drill at the same time, hopefully this works
Old 05-10-2004, 12:53 PM
dvandentop's Avatar
this was for a friends install not my car but yeah this does suck but what can ya do
Old 05-10-2004, 01:19 PM
HumpinSS's Avatar
yes that is the case they are a lot better IMHO than an Easy out
Old 05-10-2004, 05:02 PM
Tech's Avatar
You drilled all the way through it?
Old 05-10-2004, 06:29 PM
Zero2Sixty's Avatar
Sears PN#52315, worked great for me.
Old 05-10-2004, 08:11 PM
dvandentop's Avatar
yes see above pic there isnt much broken off in there
Old 05-11-2004, 11:21 PM
dvandentop's Avatar
tr6's
cobalt drill bits
2 sets of easy outs just incase one set doesnt suffice
and YES JOSH! even a drill bit extension!!!
