lq4 with 60cc heads.
Guys what would compression be lq4 with 60cc 243s and .051 gaskets? I come up with 10.8-9 comp.
What about dcr with a cam of 46 adbc at .050?
This confuses me like crazy. Im thinkin about milling heads for more comp and higher dcr.
Thoughts? Thanks
Thoughts? Thanks
I cant comment on you DCR but SCR looks "about" right. When I put unmilled TSP Stage 2.5 5.3's on my lq4 they told me I would be at 10.6:1 with stock HG. Those start out as 862's which are 61ish if I remember right.
So my dcr is very low right now. What would u guys do? Is 11.2 scr at 58cc with stock gaskets? What about runnin a .040 gasket with 58cc?
I want to try and get every bit of power out of this setup. Im kinda leaning toward around a 8.7 dcr. No higher than 11.5 scr. Also ptv will play a big role in this. Maybe martin will chime in on this.
What was your P to V before the first time you measured? If you want to mill your heads, you'll need to subtract the amount you want to mill from the P to V measurements you took the first time you did them.
IIRC you have the SNS Stage 3. You'll want to use the advertised intake close event and not the @.050" event. The intake valve closes @71.5* ABDC. Use this figure for your DCR calculations.
