Lifters?
Lifters?
I recently had a lifter twist in the bore and screw up my MS3 cam. I had 853 heads also. Now Im gonna do a set of 243's and either a MS4 or BTR stg4 cam. I need to decide on lifters. I really dont want this kind of thing happening again so I was thinking of doing the Lunati lifters with the link bars. Are these a good lifter to run? I know most people say to run the LS7 lifters but the link bar kinda give piece of mind.
Thanks for any help you guys give.
Jimmy
Jimmy
We have a nice set of Morel Tie bars available. Here they are. No need for the plastic trays! They also give a little bit more stability in the higher rpms.
No, and just add a little assy lube to the roller and the body and drop them in. There are more heavy duty ones out there, but for your intended purposes, I think they are the perfect fit!
I have the hi-rpm ones.No problems with them. I went with link bars because the trays can wear out, allowing your lifter to spin. The link bars cant twist at all.
Im actually selling a set, btw. haha
We have the Morel "street" link bars for $329, and the high rpm set can be had for $579.
One of the better things about the link bar lifters is, you dont have to worry about them falling in the bottom of the engine when changing cams! Ha.
