Total parts cost/machining for a 408 iron block and bottom end?
My brother is looking to do a 408 iron block motor. We are curious as to what the cost would be for just the parts and the machining, unassembled?
-Iron Block, machined and ready to assemble
-Bearings
-Diamond 4.030 pistons/rings
-Callies crank
-Eagle Rods
-ARP main bolts and rod bolts
We want to buy all the tools and assemble it ourselves.
We'd also have the rotating assembly balanced by a machine shop.
-Bearings
-Callies crank
-Eagle Rods
just had the same short block built(only difference is mine is a 4.06 bore and i used the rod bolts that came with the eagle rods) by a local machine shop it cost me $4800 assembled.assembly was $300 so if you wanted to do it yourself you could save that.
ps spend the extra money and get it assembled this way all clearances are cheched.if you assemble it your responsible ,its the assemblers job to check for any problems.
Originally Posted by StupidFast
I got my 408 rotating assembly from AP Engineering for a perfect price. They also build short blocks for cheap also. Nothing but great to deal with.
I 2nd that the guys at AP Engineering are awsome........ Great customer service also.
Under criminal investigation for fraud
-Bearings
-Callies crank
-Eagle Rods
-Bearings
-Callies crank
-Eagle Rods
Levi,
Iron block ready to go - $1200.00 (core charge included)
Main & rod bearings - $112.00
Diamond 4.030 pistons & rings (shelf stock) - $825.00
Callies 4" crank - $1650.00
Eagle H beam con rods - $440.00
ARP main bolts - included w/ block machining!!
If you have any questions just let me know.
Thanks
Originally Posted by Chris@AP-Engineering
Levi,
Thanks
Thanks
