Compression ratio question
Old 04-25-2014, 01:15 AM
lsxnoobneedhelp's Avatar
Default Compression ratio question
LIKE MY NAME SAYS
The engine builder told me the compression ration will be 11:2:1 with the parts I'm using, but when I put in the info into a compression calculator, it comes out wrong
Its a lq9 bored to a 408 (4.03" bore/4.00" stroke)
-3cc wiseco flattop pistons
68cc ls3 aftermarket heads
.051" head gasket
and a lq9s deck clearance is 9.24
When I put all this into a compression calculator, it came out to be 1.42:1
Old 04-25-2014, 01:40 AM
Werewolf SS's Avatar
Your builder is correct. Your combination would be a 11.2 : 1 .The calculator you used is either messed up or a value was incorrectly entered. I have the same setup except my pistons are -1.8cc and my headgasket is .041 and that gives me a 11.6 : 1 ratio.
Old 04-25-2014, 01:42 AM
98TransAmWs-6's Avatar
You are doing something wrong then. I did the calculation and it comes out to 11.23:1.
Old 04-25-2014, 02:06 AM
What calculator are yall using
Old 04-25-2014, 02:16 AM
just type in compression calculator on google. Most use the first one but any of them should be fine. Deck height is only used to figure out if your piston is going to stick out of the hole any. No calculator will you actually put 9.24 for deck height. I think that might be what has messed you up.
Old 04-25-2014, 02:20 AM
I think that's it too, what should I put for deck height when I try to calculate it?
Old 04-25-2014, 02:48 AM
zero unless you know if the piston will stick out a certain amount (somewhat uncommon with aftermarket pistons to my understanding.)
Old 04-25-2014, 02:53 AM
Awesome, thanks for the help
Quick Reply: Compression ratio question
