Cutting TFS valve spring seats.
I have a set of TEA trickflow 245's with K-800 springs intalled at 1.790. I need to set them up around 1.810 - 1.825. How much can the valve spring seats be safely cut? On my invoice says they have 1.550 locators but I checked and they are 1.46 x .062 thick .569 ID and they fit pretty snug. Spring seats are probably 1.48 diameter. I couldn't find any thinner locators that match this size. Thanks in advance.
Go to PAC Racing online catalog. Pg. 33 has a lock standards measurement for most common locks. You will be measuring the cone of the retainer to find this info out.
http://www.racingsprings.com/Multime...ainCatalog.PDF
Thanks guys. Was that a conformation that I need the standard 7's? PAC-L8153 I looked in the PAC catalogue and it doesn't show how to tell the difference between standard 7 and LS 7 locks. How do I tell?
We have a great price on shims. http://www.briantooleyracing.com/shi...ck-guides.html
Ok great. thanks Brian. Can I get those and a set of seals from you? .569 guides. Intake and exhaust seals are a different color. I think one is brown and the other black.
http://www.briantooleyracing.com/ls-valve-seal-kit.html
