LS2 or LQ9 piston/rod assy in a stock crank LQ4?
recently blew a hole in the side of my stock 2003 LQ4 block. I was running a completely stock bottom end (crank, rods, dished LQ4 pistons). The only internal modifications were a 228R TSP cam. Heads were 317s milled .026" for a 66cc chamber to bring compression back up.
Now that the block is toast (along with 1 smashed piston and broken rod), I'm tossing around the idea of throwing in flat-top pistons to raise compression even more. Here are my questions:
1. Provided I can pick up a used set, would a set of stock flat top LS2 or LQ9 piston/rod assemblies bolt up to a stock 2003 LQ4 crank? I would be installing new bearings for peace of mind. I also would not be trying to retrofit LS2/LQ9 pistons onto LQ4 rods (I'm aware of the pressed/floating wrist pin difference) - it would be an LS2 or LQ9 rod/piston factory assembly going onto the LQ4 crank.
2. One of the 317s was trashed when the valvespring broke (valve gouged the combustion chamber). One option I have is to buy another 317 head cheap and have it milled to match the good one on the motor. If I go with this route, will I have to worry about PTV, given a 228R cam (.588 lift) and flat tops?
I used LS2 rods and Flat top Wiseco pistons in a LQ4 with .585/585 lift cam with no problems. Heads were stock 317, but I don't think you will have ptv clearance problems. I'm getting ready to put a set of 2005 GTO LS2 rods for sale on here tomorrow.
3-year old thread; you MIGHT get an answer.
