Found THIS in the oil pan
was changing the oil on my old man's 02 ss when I found this nice scrap among other crescent shaped shreds..........
what might this be? haven't pulled the oil pan yet. will do soon.
That's MISTER MODERATOR
Yeah, take some more pics without holding it-and not in a shadow. Place it on a table, move back just a bit.
Did these things come out the oil drain plug hole into the drain pan you're using?
Looks to be deceased cam bearing remains.
How did this engine run? Any noises, banging or knocking?
How many miles on it? Well cared for or well beaten?
https://ls1tech.com/forums/generatio...g-threads.html
Its definitely not a crank, rod or cam bearing. I was also thinking a trunion bearing but wanted a more clear picture to be safe. That last picture looks like a valve seal band broke but its too big I think..
And BTW. Its VERY easy for anything that comes from the top of the head to end up in the pan. Unless it gets caught up in a small valley, it only has one place to go, and that's down.
